The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Scoped Sandbox creation including or excluding multiple file extensions from the GUI
We wanted to create a Scoped Sandbox with only *.c and *.h files.
Scoped Sandbox creation including or excluding multiple file extensions from the GUI is not possible for the moment, only from the command line.
It would be great, if this were possible also in the GUI. I attach a screenshot.
5 Comments
uminet
I think you can try to use Java Syntax in the GUI, i.e. "*.c|*.h"
pbartha
7-Bedrock
Hello Uminet,
have you tested what you have suggested? It's not working unfortunately 😞
uminet
it works for me in a sandbox in 10.9 ... do you use any blanks? "*.xml | *.txt" doesn't work, but "*.xml|*.txt" works fine
pbartha
7-Bedrock
Hi Uminet, it works finally as that:
*.config|*.txt
Thanks a lot for the hint, topic can be closed I guess. Bye, Péter
Siddharth
9-Granite
Status changed to: No Plans to Implement
