Search and Replace text in a Document
A simple feature like "Search and Replace", within Lifecycle Manager, would be extremely valuable.  Search without replace is vastly more time consuming.
8 Comments
GauravPhadtare
Status changed to: Clarification Needed
@garykempen Could you please confirm you mean "Find and Replace" instead of Search and Replace?
garykempen
2-Guest
I wasn't aware there was a meaningful difference, so yes, call it either way.
GauravPhadtare
Did you try the new rich text editor from Integrity Lifecycle Manager 12.2.1.0 release? It has the capability to Find and Replace content.
GauravPhadtare
Status changed to: Current Functionality
JensN.
Is this "Find&Replace"-Functionality in the new web UI usabel to replace a text in a whole document or only in one requirement? If it's only working in one requirement than it's nearly useless or at least extremely cumbersome.
best regards, Jens
SP_9600800
7-Bedrock
I request PTC to enhance/improve "Find and Replace" functionality in PTC RV&S, currently user is able to "Find and Replace" when a section inside a document is selected.
Whereas It would be more useful "Find and Replace" which works on complete document is implemented.
For ex: Select the root document and search for text which gives instances for text in complete document and replace If user wants.
Users want to work/create/update documents in PTC RV&S, Find and Replace is a common functionality used when working on large document, Surprisingly not available🤔
BaluSri
6-Contributor
Upvoted this idea. We are looking for a "Find and Replace" or "Search and Replace" throughout the document. Current functionality only works within a single field in an item.
KartikOak
Status changed to: Duplicate
Marking it as a duplicate of another Idea that is being used to track this same topic.
Search & Replace functionality for Winchill RV&S (... - PTC Community
From a research point of view, we are currently looking at the front & back end design to achieve this. This may have to be designed as a fire and forget given the number of content items that would have to be trawled through vs preselected content that the user wants to run this on are some of the possibilities that are being reviewed.
Kartik Oak
