Problem:
The selection of elements such as ports in internal block diagrams requires that the whole element including the names are within the selection frame. In cases with many names it is very difficult to get only the intended selection of ports.
Suggestion:
Change selection of ports so that only the port element but not the name must be within the selection frame.
