Users would like to optimize their charts through automated sorting. For instance a Pie chart where the first segment is always the largest. Or a distribution chart sorted from large to small, like a Pareto.
Cfr.: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS162673
Cfr.: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS85363
