- Support of Configuration Path Syntax
- Integrity Source Flat Path Syntax should be removed/ deprecated
- Source Configuration Path vs Flat Path obsolescence
- Enhance support to address the areas of the product that still use legacy syntax (flat path) instead of the Configuration Path syntax:
- Change Package Details view
- Member & Revision Information view
- Projects view
- Receiving the below error while trying to create a normal sandbox using flat path via GUI / CLI:
- Failed to create sandbox: MKS125443: The subproject <SubProject>/project.pj does not exist (anymore)
See also article CS84840.
