It would be nice if the gui could be started with a viewset parameter.
Viewset are a good way of separating/organizing features of integrity by different user-roles, use cases, or process areas.
Currently only admins can only publish mandatory viewsets to the client of a connnecting user, but you cannot "enforce" the user to use these.
As Integritry is able to cover a wide range of scopes, it would be nice to have the Option to start the GUI especially for one selected viewset.
Even better would be the possibility to do this via an "integrity://serverort/...." Hyperlink.
For example in a process driven environment you could send a email to the assigned user of a certain task, including this link
(something like "integrity://<server>:<port>/im/viewsegment?selection=<ID>&viewset=Requirement_Document_Review")
and thereby ensure, that the intended usecase can be fully covered, as all (and only the necessary) GUI settings are given.
Please vote for this IDEAs
Enable one instance of client GUI per viewset
Make viewsets "shareable" like queries, charts, reports and dashboards
as well
