Please inform when MS SQL 2014 will be supported.
Our IT department will upgrade the corporate cluster, on which Integrity is running, in 2017. So this is suddenly becoming urgent for us.
Related article: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS195442
