Currently, Integrity system supports user-customized revision number for individual member.
For example, following member revision history is possible.
ex) 1.1 -> 1.2 -> 1.8 -> 1.9 -> 2.0 -> 2.1 -> 3.1
But, same concept of project revision numbering is impossible.
Only support serial number after "1." like this.
ex) 1.1 -> 1.2 -> 1.3 -> 1.4 -> ..... -> 1.135 -> 1.136 -> 1.137 ...
We can utilize 'Label' function,
but sometimes want to give more meaningful number for project history.
So I suggest support user-customized revision number for Project Checkpoint.
Does the PTC have any plan on this issue?
