Test Cases do not retain ordering when selected in the finder dialog for a Test Session
When selecting Test Suites or Test Cases on a Test Session, the ordering is not maintained after finishing with the Document Finder dialog. This feature was never designed to keep the order so this Idea requests an enhancement to change this behavior.
Attached is a document showing the steps to reproduce the behavior.
3 Comments
gidskeys
3-Visitor
This was a feature in 10.4 and we lost it somewhere in between 10.4 and 12.3.1 the version we upgraded to. Could really use this fix, because without it our test our test managers are spending hours to reorganize the test cases selected after they are added to the test session. Where before it would only take minutes to create the test session and add the test cases. The way to keep order right now doesn't work for our company. because not all the cases get ran if we select an entire test protocol which the results are then inaccurate.
KartikOak
Status changed to: Under Consideration
KartikOak
Status changed to: Delivered
This functionality has been fixed in Windchill RV&S 12.4
Please review and provide your feedback.
Kartik
