We are looking at the possibility for the test Objective/Test Session to import test cases from test document via filter.
E.g. Import all with “Test Type” = “System Test”, and/or column "additional comments" includes Text "xyz".
Currently in Integrity test management solution the "Tests" relationship field relates a test objective to test cases and for this relationship field it is not possible to customize filters as mentioned above.
