For any field type defined as Short Text or Long Text, display a text suggestion as users begin typing into the text field. It should have a 'lookback' type feature for same fields within the same document.
It can either pre-populate the text field based on the letters already input, or display a dropdown with a number of suggestions. This similar behavior can be seen in how a search engine will provide suggestions.
