The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
The Picklist values in some of the functions are incomplete. (View Differeces-Attributes)
PTC Case: C14684958
E.g. Filtering, Queries and so on.
In the attached picture you find the incomplete list when you want to compare documents and focus on certain attributes. (Assigned to user or group)
Benjamin Stichnoth    6/12/2018
26th July:
Problem: Certain Deere created fields are not visible in certain search engines.
Scope:
  1. View Document Differences:
    1. Assigned Reviewer is not visible in View Document Differences window search box.
    2. Options is not visible in View Document Differences window search box.
  2. Additional Fields to Compare: The following picks are missing from the
    1. Outline
    2. Requirement Stage
    3. Originated by User or Group
    4. Assigned to User or Group
    5. Relevant to User or Group
    6. Reference Source
    7. Lead Reviewer
    8. Region
    9. Release
  3. Document Name is not visible in Edit Chart window search box.
    1. Andrew and Alonzo just confirmed that the fields which are not getting visible in Edit chart, are not picklist. So we are good with Edit Chart window search box.
Steps for above example 2:
  1. Go on Document and compare the document and go on View Document Differences.
  2. Click on Additional fields to Compare and click on Plus sign.
  3. Search for Assigned Reviewers
  4. Actual: List showed up empty
  5. Expected:
    1. System should display the list of search words.
1 Comment
KartikOak
Status changed to: Archived
There are multiple ideas mentioned in a single post. Please break these into different areas, so we can track this in a better way.
Kartik
