There should be some way to make "Create Related Defect" mandatory in case of failed test case in test session in Test Result Editor.
4 Comments
VolkerEckardt
Hi Kapil,
very good request.
One of my clients has created a trigger which validates as soon as you try to close the test session that any faild test case has a related defect attached to it.
Is this something which would fulfill your needs?
Volker
kjain-2
Hi Volker,
Yes you are right there is only single way "By Trigger".
But i want to check is there any better workaround or something OOTB, so as you replied i got my answer.
Can you help me little about trigger code if possible?
Thanks Volker.
Kapil
VolkerEckardt
Hi Kapil,
there is not exactly a script which does the job already, but there is one in standard available which i would use as a starting point.
Attached for you.AddDefectToTestCase.js
KartikOak
