The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Token Tunnel SysML in Diagrams
0 Kudos
I would appreciate if the PTC Modeler supported SysML token tunnel in diagrams. This would lead to a better overview when several connections are used between elements which are spread over a diagram.
Please see the attached figure as an example for token tunnel.
David
4 Comments
DS_10069093
9-Granite
Here is one more figure of oose for illustration:
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (questions below). The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
DS_10069093
9-Granite
thanks for your response and the link. I added the information below:
As a solution architect in the medical device industry I support users of the MBSE tool PTC Modeler.
PTC Modeler 9.3
The use of many connections in an activity diagram (sometimes unavoidable) is at the expense of clarity and leads to crossing lines.
The product architects would like to apply SysML token tunnel (marked red in the picture below) to make activity diagrams with many connections clearer.
The suggestion would lead to a better overview when several connections are used between elements which are spread over a diagram.
David
olivierlp
Community Manager
Thank you @DS_10069093 for your idea and the information provided.
