URL for Item attachments?
wstokes
6-Contributor
I have a series of scripts which interact with Integrity using the CLI via. Python subprocessing.
I can easily extract information relating to a particular item with
im viewissue
and then use Python to parse the output and extract the information I want.
What I would like to do is generate a list of URLs for the attachments associated with each item.
I am aware of
im extractattachments
but this actually downloads the files from the server. The issue with extractattachements, is that I plan to process many items, each with multiple attachments. Of these, the user may be interested in only a handful, so downloading them all would be wasteful. I would like to present the user with the links, which they can click to download the files if they choose.
Is this approach possible? A compromise would be a link which opened up the item in the Integrity GUI (or web client) on the attachments tab?
Thanks in advance
Will
1 ACCEPTED SOLUTION
Since you are parsing the output of im viewissue, adding the option --showAttachments will add a list of all attachments to the CLI output.
Once you extract the names you can simply generate links to each of the individual attachments via the pattern http://<servername>:<port>/im/viewattachment?issue=<item id>&attachment=<attachment name>
wstokes
6-Contributor
(To:pmaechtlen)
@pmaechtlen,
Cool thanks this is what I was looking for! I could already get the attachment names from 'im viewissue' but I wasn't sure about how to construct the correct pattern to actually form a link to that attachment. Your solution worked great!
One point to note:
im viewattachment
does not show up when I type
im --usage
at the console. Is it undocumented?
This is correct, im viewattachment does not exist as a CLI command.
This is exclusive to the web-access URL schema.
wstokes
6-Contributor
(To:pmaechtlen)
OK, that is interesting.
Are there many notable differences between the documented CLI commands and the web only commands? I find the general documentation on this to not be great, but perhaps I not always looking in the correct places.
If you have any helpful links that would be greatly appreciated - especially for the web-related commands.
Will
