Users would benefit from an "Assign To Me" feature. It's possible to use the -me- option in filters, but it would be an improvement if this would be possible as an option in user fields too. Our use case is typically for the Assigned User field, but this is of course valid for user fields in general.
Current option in filters:
Cfr: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS88098
