Unlock Locked Nodes
SOLVED
Regular Member
Unlock Locked Nodes
There are two nodes in a document that say they are locked. How can I unlock these? After a certain amount of time does the lock expire?
Re: Unlock Locked Nodes
I think a script may be stuck in a loop. We're going to bounce the server later to fix this.
Hi Nolin, Did bouncing the server fix that? Regards, Kael
Kind Regards,
Kael Lizak
Yes it did. I think there was a script stuck in a loop. Let's just say I missed some brackets in a trigger script...
