Update the server-side scripting engine to support the latest capabilities of the JavaScript language. For example, the current engine (which we speculate to be Rhino) does not even support JSON functions.
This functionality would be used in multiple capacities - mostly to get around limitations of the Integrity engine. Currently, our solution builds summary and history tables to keep track of data that is difficult to track any other way in Integrity. Then that data is extract from Integrity for use in spreadsheets, scripts, reporting engines, etc.
Supporting JSON would make integration with other tools, and the supporting scripts that we must create, much easier.
