Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
I would also like to see any sort of options/filtering for a window saved along with the window size. For example, if a user has a sandbox window open with filters defined, the filters should be saved as well.
Of course, any option to save settings for a window should be accompanied by some sort of reset option, for users that get themselves into a position where they're really made a mess.
And all of this would ideally be combined with the other enhancement request looking to save these types of settings to a server-based profile instead of just locally.
