Customer is using the ILM v10.9.
When the user who uses the dual monitors clicks the ILM field menu(ex: drop-down list menu), some pop-up windows displays on the main (1st) monitor not current (2nd) monitor.
The customer wants that the menu window is popped up at the current monitor where the user clicks the menu not the main monitor.
