We want CLI to support parallel processing by CMD "start" command.
0 Kudos
By parallel processing, processing time can be reduced by 70%.
However, the operation is not guaranteed at present.
For example, when acquiring by parallel processing using the CMD "start" command in the CLI "si viewrevision", there is a problem that the keyword "$ date $" value of another file is replaced.
1 Comment
GauravPhadtare
Status changed to: No Plans to Implement
