Hello Support,
In the ADMIN CLIENT GUI under "Configuration Management-->Permissions-->Global" there is a possibility to add "Security Principals".
Is there any CLI to view the list of Security Principals as they are available within the presently configured GLOBAL Tree?
Thank you.
Hello Pashan None
You can use the following command:
aa viewacl --acl=mks:si
This will give you the principals and there given permissions.
Dominik
Hello Pashan None
Dominik
