What is CLI to view GLOBAL permissions
pnone
Hello Support,
In the ADMIN CLIENT GUI under "Configuration Management-->Permissions-->Global" there is a possibility to add "Security Principals".
Is there any CLI to view the list of Security Principals as they are available within the presently configured GLOBAL Tree?
Thank you.
Regards
1 ACCEPTED SOLUTION
Hello Pashan None
You can use the following command:
aa viewacl --acl=mks:si
This will give you the principals and there given permissions.
Regards
Dominik
Hello Pashan None
Regards
Dominik
