When print menu in tool bar is hidden, print button on item window should be hidden or grayed-out.
0 Kudos
Our customer wants to thoroughly hide/disable the OOTB print function of Integrity.
    * The reason is mentioned in the idea titled:
       'Functionality to print item info based on an idea: "What you see is what you get" '
In order to do so, we hided the print menu by setting
Item Detail View Customization [window ]-> Action [tab] -> View [action group] -> Print -> Action availability
to hide(or maybe disable).
With the above setting, the tool bar "Print" menu disappears but the print button on item window still remains the same. We want the Print menu to be hidden or disabled(gray-out), in order to prevent users from deciding "Integrity froze-up".
4 Comments
ymizushiro
Posted SPR 9533512 by Tech Support.
GauravPhadtare
GauravPhadtare
Status changed to: Under Consideration
olivierlp
Community Manager
Status changed to: Archived
