The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
I am trying to create a User Defined review where I am extracting the Blocks having custom stereotype ("testStereotype") applied, which is working fine but I also want the final count (In Reviewer "Out of" Count) of all the available Block, for which I am using .itemCount as shown in attached image. It looks like the items.Count is giving the count for first value of 'var' instead of letting the loops complete and giving the count. Please let me know if someone can help on this.
I'd suggest you raise with PTC Support to check if this is a bug.
thanks,
Patrick
