When you are working with Catia V5 in Windchill WGM you are able to manage so like different Customer environment(Catia Release is missing there).
Same functionality should be added for NX or maybe also other CAD application.
We have to manage files from different customers with different NX version and environments. You should not be allowed to edit objects in the wrong environment, or newer release if this is not new one for your customer.
