Windows Task Scheduler
ptc-5173997
1-Newbie
I am using windows 2008 Server to schedule some tasks to run on a certain time. Installed on this Server I have Integrity client 2009/SP6.
I have a smal batch si commands which can not be excuted from the windows scheduler. Any othe CMD Batchfiles are working just fine. MKS Batch files are not. I have tried many settings, nothing worked. Do anyboday have an idea?
1 ACCEPTED SOLUTION
The hanging symptom in batch jobs is indeed very tricky! It's caused by the fact that the Integrity client stays running unless you proactively shut it down. A subsequent instance of the batch job may be unable to connect to a client started by a prior instance. To prevent this kind of thing, you need to design your batch jobs to begin with "si.exe connect" and end with "si.exe exit --shutdown". I have done so and found it to work very well.
4 REPLIES 4
I've done lots of successful scripting with 2009sp6. I am very sure that it works and works well. Perhaps you could elaborate on what command you are running and what error you are seeing.
I `ve found the reason, when the integrity run`s in the background it hangs some times I do not know why
The secound time the client want`s to start it crasches cause of the existing client in the background. Know it works fine.
this is exactly what I have done yesterday 🙂
