it would be great if Integrity/WindchillRVS supported such feature:
at a document (which has other included documents under it), so at this main document word export action users would be able to specify the different Included documents' baselines/labels and it could export the (included) documents as of the state of those specified baselines/labels.
For now these documents you have to do indeed one by one as of the state of the specified baselines/labels.
(This problematic would also be somehow solved if documents/segments - as of a baseline could be added under a main document (under a collector document of other documents/segments) for the sake of the word export.
