ability to batch edit test results inside the test result editor in Integrity
0 Kudos
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Automotive/Rail
2. What product and version are you currently running?
12.5
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
we are aiming for possibility to batch edit test results inside the test result editor in Windchill RV&S (Integrity).
this applies to batch Edit for Verdict, Annotation, and marking other Verdict fields.
also the user should be able to take multiple failed cases and create a single related defect for all those cases
4. What is the use case for your organization?
better and faster documentation and test execution method we are trying to achive.
5. What business value would your suggestion represent for your organization?
5 Comments
olivierlp
Community Manager
Thank you for your idea, @kokici. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
KartikOak
Hello Ivica,
                     Thanks for raising this Idea. From the information shared above - we seem to be missing some steps. Please review the images below that are from a 12.5 instance today. Doesn't that solve your Idea? If not, please help by clarifying the missing steps.
Kartik Oak
kokici
8-Gravel
thanks for input
KartikOak
Status changed to: Current Functionality
Hello Ivica,
                     I'm closing this, if after you try this out and see gaps in your needs - please open a new Idea with the exact requirements.
I think you will agree, that this topic can be closed.
Kartik
kokici
8-Gravel
perfect. Thanks
