define view option defaults for floating views
mrump
I have to admin and support some hundred installed clients and what I really miss is a way to publish a "complete" default configuration for the client gui.
I do know how to configure a viewset and all it's option:
- menu content (which command is visible (on Toolbar ) or not )
- view behavior (floating or "inline" position)
- content of context menu's in views
But all these setting do only apply for the viewset's "inline" views.
I have no idea how to define the default settings for a floating view, especially things like:
- a default filter for the project history view
- the content of the context menu in a sandbox view
- the command available in the menu of an Item detail view
Any ideas ?
khoppe
(To:mrump)
I'm afraid it is to late to raise this point as idea, since PTC is working on a web-based client.
But maybe they will be "happy" to get the idea for new WebUI ?
PS: It looks like (from time to time) in 10.9 client (our default now) settings changes in floating views will be stored in the viewset file.  Did you notice same?
Best regards,
kthierer
11-Garnet
(To:mrump)
I used "Cutomize This Menu..." in a floating sandbox view which I started via commandline
(si viewsandbox --gui).
There I added "User Action 1 (Custom)" to the popup menu
I found the following file beeing modified:
c:\users\user1\.mks\viewset\view\mks_ic_si_ui_swing_SandboxView.vs
By merging lines from my regular viewset containing "ActionDef.user.1."
into this file I could at least implement a valid user tool for the floating view.
Maybe this could be an approach for finding a solution
Regards Juergen
