document reviews in integrity
SOLVED
Participant
I am wondering about how is the best way to make a document review in integrity.
Our first idea was to use the change request and change order mechanism, but it seems to complex for this task.
Now we are thinking to use to comment fields for every item, one to describe the findings, the other to describe the decision.
After the revision we baseline (or check in??) the document. Both comment fields should be deleted with a script (to be written) for the next review.
Is there any other way to make reviews on a simple manner?
btw.: in 10.5 exists a new function called Create Review Session. Is somebody using this? How it works? On every documenttype I receive
a message (attachement)
Thanks a lot for your hints,
Bernd
Re: document reviews in integrity
Hello Bernd,
This Create Review Session functionality is not documented because it is not complete.
For more details on these types of things, see CS162703: Integrity Technical Previews.
Kael
Kind Regards,
Kael Lizak
Why would you want to delete the comments? Is the document an attachment?
The document is not an attachement, it's an integrity document.
The review findings should apply to a specific baseline of this doument.
I dont want read the review comment from a earlier baseline of the same document, this is because we delete
the comments for every new baseline.
Hello Bernd,
Kael
Kind Regards,
Kael Lizak
