document view: enable filter per section
Intended usecases:
u1 : View / edit only a selected (sub-) chapter of a document.
u2 : Export only a selected (sub-) chapter of a document using the gateway.
Drawback:
The "where.." filter does not support the "section" field  (Status Quo : I11.0 )
The gateway export only accepts filters that are defined using the "where.." filters in the document.
-----status quo -----------------
The only way to filter the document view for a certain "chapter" is the "show items containing..." text filter, which is not working well
and the Gateway rejects exports for there documents as the text fitler is not supported:
So please add the "section" field to the elements that can be handled by the "where.." filters and thereby enable the export usecase as well.
4 Comments
KartikOak
Hello Matthias,
                        I have flagged this Idea under Future Requests. We will evaluate this request when we start reviewing enhancements related to the Document View filtering + Export.
Kartik Oak
mrump
Hello Kartik,
that's good news. Hopefully this feature makes it into the next version.
Kind Regards
Matthias
kokici
7-Bedrock
@KartikOak  any plans on having this in one of future releases?
KartikOak
