eMail notifications
DanR.
eMail notifications
How can I make the email notifications show the link(s) in HTML format, i.e. clickable link?
11 REPLIES 11
KaelLizak
(To:DanR.)
Hello Daniel,
Is this an item notification, or an email sent by a trigger?
Kael
Kind Regards,
Kael Lizak
DanR.
(To:KaelLizak)
Both.
If you're using emailAdvanced.js, you'll want to use <%ID%> for the ID number. If you want to do a link to an issue in email, you can generate an HTML Anchor using the general form:
<A HREF="http://ptcservername:portnumber/im/viewissue?selection=<%ID%>"><%ID%></A>
and it will generate a link with the item number.
That I already knew. The emailAdvanced.js was easy.
Thank you for your response.
The emailAdvanced.js script works for one item at a time, e.g. one email is sent for each item.. I have scheduled triggers that have queries which have dozens of items and would like them to show in ONE email not dozens of emails..
DanR.
(To:DanR.)
I wonder if the emailAdvanced.js could be modified to send an email of the entire query (e.g. ALL items in the query) , instead of an email for each item in that query. Does that make sense?
DanR.
(To:DanR.)
Anyone??
KaelLizak
(To:DanR.)
Hi Daniel,
Certainly, that makes sense!  It's just that it's non-trivial, and it looks like it's not something someone has done before.
Sorry,
Kael
Kind Regards,
Kael Lizak
DanR.
(To:DanR.)
Anyone???
DanR.
(To:DanR.)
Anyone?  Please.
LLawton
(To:DanR.)
Modifying emailAdvanced for this purpose is not practical, it's a massive script.
I have the same problem and I've decided to come up with a report that shows all the items I want to include in one email, then send a simple email with a link to the report. Actually, as I write this, I realize it could simply be a query and bypass the report altogether.
The problem is, I don't have time currently to do it, it's probably going to be a few more weeks before I get to it. When I have it, I can share my solution.
That is, assuming I understand this thread correctly. If you read the initial question, it's impossible to guess it's about the scenario explained in the 5th response.
