currently (I11.0) only short text is available; labels won't do the job and a workaround using a specified type + IBPL or QBR fields is way to complicated.
So please add the feature to TAG single or multiple item with one or multiple short re-usable text TAGs.
Just like in this community, we would like to have an easy, self-explaining way to organize/classify random items (or members/projects in SI) that share common "topics".
These topics can be dynamically created and/or reused from a given set of prior topics.
In contrast to the given relationship model:
- there shall be no need to leave the focus of the current item (vs. "create related item ...")
- it shall be possible to create and use a TAG during the editing of a current item (vs. to us an IBPL field, the "TAG-Item" must have been crated prior to the editing of the current item)
In Source the "member attribute" seems to be a comparable concept.
