I just tested it on 10.9:
in the Web interface ther is no way to enter the members or projects content AT ALL for source link or source trace fields.
A behavior similar to the double click in the fat client (that opens either the project view, the member history view or the member content directly) is needed in the web interface
All necessary information to create a valid Hyperlink to the cureently available SI Web interface is available, but for some reason the IM Item view does not use it !
Security should not be an issue, as the ACL handling for the stored members or projects is not affected.
