getting detail information about attachments(Attachments, Shared Attachments, Text Attachments)
mhyang
9-Granite
I know that getting detail information from a issue(Item) is
in CLI
$ im view issue 2
in Java API
Command cmd = new Command(Command.IM, "viewissue");
cmd.addSelection("2");
In result, I get the fields of the issue(item) that I selected.
Shared Attachments:
shared.txt
Text Attachments:
text.txt
attach.txt
Not just names of the attachments, I want to know the detailed information of for each attachments (text.txt, attach.txt, share.txt...) such as created by and created time.
I know that the detailed information of each attachments is shown in the GUI client when view detail of the item.
How can I retrieve those information by CLI and Java API?
1 ACCEPTED SOLUTION
awalsh
(To:mhyang)
Try using the option "showAttachmentDetails".
On the CLI, the output is like:
MKSImg8987741183544506197.png (5567 bytes)      awalsh  2-May-2016 9:58:41 PM   Attachment added automatically by rich content  image/png       bfecae030292b268a8f54c9d67454ebe
In the API, you will get:
    Field:
      Name      = Text Attachments
      Data Type = mksItemList
      ItemList:
        Item:
          Context    = 2892
          Model Type = im.Attachment
          Field:
            Name      = FileName
            Data Type = wchar_t *
          Field:
            Name      = FileSize
            Data Type = int
            Value     = 5567
          Field:
            Name      = CreatedBy
            Value     = awalsh
          Field:
            Name      = DateAdded
            Value     = 2-May-2016 3:58:41 PM
          Field:
            Name      = Summary
            Value     = Attachment added automatically by rich content
          Field:
            Name      = ContentType
            Value     = image/png
          Field:
            Name      = Checksum
            Value     = bfecae030292b268a8f54c9d67454ebe
          Field:
            Name      = AttachmentID
            Data Type = int
            Value     = 46
2 REPLIES 2
awalsh
(To:mhyang)
    Field:
      ItemList:
        Item:
          Context    = 2892
          Field:
            Name      = FileName
          Field:
            Name      = FileSize
            Data Type = int
            Value     = 5567
          Field:
            Name      = CreatedBy
            Value     = awalsh
          Field:
            Name      = DateAdded
          Field:
            Name      = Summary
          Field:
            Name      = ContentType
            Value     = image/png
          Field:
            Name      = Checksum
          Field:
            Name      = AttachmentID
            Data Type = int
            Value     = 46
mhyang
9-Granite
(To:awalsh)
Thank you! That works for me.
