It would help a lot in daily work, if there was a way to merge two PTC documents.
Being it 2 Versions or branches of the same document or completely "disconnected" IDs.
visual draft:
source Doc <leftID> |
source Doc<rightID> |
resulting merged Doc (pending Multi-line edit view) |
The gestures/actions should be comparable to the SI Diff & Merge Tool (copy from left / copy from right /go the next diff/ ...)
It should be possible to choose whether the merge should result in new document, or updateing an existing document ID (including the <leftID> or <rightID>)
The resulting merged doc should be "Pending" like a pending Import to enable the discarding of the merge.
Reference to Article - CS90564 -
Reported to R&D as enhancement RFC 180998
