The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
possibility to batch edit test results inside the test result editor in Integrity
0 Kudos
Possibility for batch (multiple) edit of test results in the test result editor, will improve the documentation of the test results, e.g. in case many test cases are being skipped, or need to be linked to the same Defect etc
2 Comments
KartikOak
Status changed to: Clarification Needed
Are you referring to Batch Edit for Verdict, Annotation, and marking other Verdict fields? Similarly, the user can take multiple failed cases and create a single related defect for all those cases. Please provide your point of view if am missing the point?
Kartik
olivierlp
Community Manager
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
