This is a product idea conversion of case 12444712 and RFC 1031765 from March of 2015.
Some test cases will be stored in a centrally controlled area. Multiple projects will be executing the test case in their respective test sessions. The test sessions will contain attributes important to future change orders (change requests/defects). When a test case fails, we want the new change order to inherit the project and other common fields from the executed test session.
Test Case: Turn on the machine
