"Prompt for..." is partially ignored by CLI
lmazzon
this is what happens:
In the Integrity Client's preferences under Configuration Management under Connection->Prompt for the checkboxes for User Name & Password  are checked.
Yet when we use the CLI (si.exe) ,for let's say check-in, on a few machines the prompt does not happen.
Is there maybe a different preferences-set for CLI then for the client somehow, or what could be the issue here?
thanks in advance,
Luca.
1 ACCEPTED SOLUTION
Hi Luca,
It may be beneficial to open a Support case, to look at this with you.  Perhaps you have more than one connection open, in the client, or you have differing connections, amongst the open "views" in the client - assuming you aren't doing something in the CLI syntax to not prompt for the username/password.
Any ideas anyone?
Hi Luca,
