relationshipgroupby in report recipe
nborrerojr.
7-Bedrock
I have the following in a report recipe:
<!-- Walk doc -->
<%beginrelationshipsdetail Query[(walkdocordered[<%<%builtin ID%>%>])]%>
<!-- Walk relationship to find STO -->
<%beginrelationshipsdetailL2 Verified By%><%filter%>(field[Category] = "MOP Eval Criteria")<%endfilter%>
  <%beginrelationshipsdetailL3 Query[(walk[<%builtin Contained By%>]<%RelationshipL2 <%builtin ID%>%>)]%><%filter%>(field[Category] = "STO")<%endfilter%>
   <%relationshipgroupby <%RelationshipL3 ID%>%>
    <tr>
     <td> </td>
    </tr>
   <%endrelationshipgroup%>
  <%endrelationshipsdetailL3%>
<%endrelationshipsdetailL2%>
<%endrelationshipsdetail%>
The relationshipgroupby never seems to do anything. It's not even processed when I run the report. The tags still stay as-is in the output html. I want to group the items returned in the L3 query. How do I make this work?
Hi Nolin Borrero Jr.,
Since you are in Level 3 i think you need to set the correct Level. Also, you can't use <%RelationshipL3 ID%> in that context. You group by field(name) and what you are doing is inserting a specific id.
You can either do it as below (select the group by field in the Report Wizard) or set the Fieldname directly.
<%relationshipgroupbyL3 &groupby%>
<%endrelationshipgroupL3%>
Dominik
Dominik
When I do that, it does seem to process it but the report is blank. Any idea what that might indicate?
Here's where I'm at now. Nothing comes out at the L3 level.
<%begindetail%>
  <table>
  <tr>
  <th>Category</th>
  <th>DOORS ID</th>
  <th>External ID</th>
  <th>Description</th>
  <th>Section</th>
  <th>Test Objective</th>
  </tr>
  <!-- Walk doc -->
  <!-- Get Eval Criteria -->
  <%beginrelationshipsection none%>
  <tr>
  <td><%Relationship Category%></td>
  <td><%Relationship DOORS ID%></td>
  <td><%Relationship External ID%></td>
  <td><%Relationship Text%></td>
  <td></td>
  <td></td>
  <tr>
  <%endrelationshipsection%>
  <%beginrelationshipsdetailL3 Query[((walk[<%builtin Contained By%>]<%RelationshipL2 <%builtin ID%>%>))]%><%filter%>(field[Category] = "STO")<%endfilter%>
  <!-- THIS ISN'T WORKING -->
  <%relationshipgroupbyL3 ID+%>
  <tr>
  <td>Category</td>
  <td>DOORS ID</td>
  <td>External ID</td>
  <td>Text</td>
  <td>Section</td>
  <td><%groupvalue%></td>
  </tr>
  </table>
<%enddetail%>
Hi Nolin,
I responded in the Support case you had logged for this as well, but I see you have this posted in the Community as well, so I'll respond here too, in case you see it sooner, or if anyone else is curious:
It seems the relationshipgroupby tags go before (or after) the fields that are iterated. If you surround the fields with the begin and end tags, then the iterated fields are not displayed (what you see).
But if you do it this way, then you should get what you are looking for:
Change:
ex.
  <tr>
  <td><%RelationshipL3 Section #%></td>
  <td><%RelationshipL3 Text%></td>
  </tr>
To be:
  <tr>
  </tr>
This works for us.
