1. Add a 5th button for signal interactions. Currently only these 4 are available:
(Operations, Returns, Events, IO-Flows.)
2. As for operations, offer only those signals which are offered by the respective (proxy) port or instance.
tailored operation list
port typed with signal interface
port typed with operation inteface
