Around Windchill RV&S Version 11 the default behavior of viewsegment command has been adapted. Since then the viewsegment command re-uses existing (open) document view. But if contentID is used along viewsegment command the client will always open a new view. Such is quite annoying for our users.The user must be able to configure default behavior thru Client preferences.
