Example of different Multiple Assignee and Reviewers for a Change Task
Peridot
An example showing different ways that one can use Multiple Assignee and Reviewers on a Change Task.  In the example there are 3 different Change Task types configured differently to use Groups and Resource Pools.  This leverages improvements in Windchill 10.2 M030 to drive Resource Pools from specific Roles within a context Team.
(view in My Videos)
6 REPLIES 6
Highlighted
Re: Example of different Multiple Assignee and Reviewers for a Change Task
Jeff,
Thanks for the video, it shows exactly what I am trying to do.   However  I am not seeing the Participant List as is shown in the video  (see screenshot).   Is there something I need to turn on?
We are currently on Windchill 11.0 m020
-marc
Marc DeBower
You need to set a property defining which Change Task types should use the Multiple Assignee/Reviewer.  Links to Help below
http://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=ChgMgmtParticipantListEnable&action=s...
Marc DeBower‌ If you have Windchill 11.0M020 installed you need to have at least CPS04. Otherwise the wizard won't work.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS254778
This video doesn't seem to be working any more.
Hi @Greg7
The video appears to be working for me, but it took a minute for it to load on the page for the first time. Can you check again now?
It still won't work in either Chrome or IE.  When I move my mouse over the black screen it shows me this.
I left it for a few minutes in each browser.
