Part II Enhancements on Windows Explorer Integration for Windchill Desktop Integration 10.2
Re: Getting the most from the WVS Job Scheduler
Gary Jackson‌,
Still looking for an answer to question #1.  Thanks.
I ran the makeCommonUtils.bat and that went fine.  I then attempted to run makePublishUtil.bat but that prompted me for Oracle DB information.  We are using MS SQL server.  Should I point these prompts to the MS SQL equivalents or will they only work with Oracle?.
Tom Uminn wrote:
Gary Jackson,
Still looing for an answer to question #1.  Thanks.
The query script in the source in PublishUtil.java & PublishUtilNoRep.java works for Oracle only, you will need to convert this to MSSQL before using the command-line utilities for an SQL Server configuration.
I'll add a note to the article to this effect.
Okay, thanks.  Maybe just make sure the note doesn't include that restriction for the PublishUtilreadCSV.  That one is working fine with MS SQL.
The note is against the command-line tool only.
Gary
