Have you ever had an issue in Windchill for which you had to raise an Enterprise Down (EDOWN) case with PTC Technical Support?
An EDOWN situation is the equivalent of an emergency room need: the Windchill server is down or unresponsive, productivity is crippled and the user community is impatiently waiting for updates on what’s going on and when the server is back up. It’s a pretty stressful environment.
Having a support contract and the possibility of raising EDOWN cases is good to fall back on, but it’s similar to having doctors and dentists around: it’s comforting to know that they are there, but we’d rather prevent the need of their services in the first place.
This is what this post is about.
We started doing analyses of Enterprise Down cases on a quarterly basis to get a better understanding of the underlying causes and see if we could work out some common practices that specifically targets these causes. Product improvements is one aspect that we are continuously working on (the Internet of Things opens up interesting possibilities), but there are actions that you can take right now to safeguard your server from some of the more common causes of EDOWN situations:
Set up a test server and use it – Any change to a Windchill server, no matter how small, can have unexpected side effects. There is a good chance that any adverse side effects will reveal themselves on the test server so that you know about them before applying them to the production system. It might not seem worth the extra cost and hassle to do this, but it makes troubleshooting so much easier for everyone involved so please reconsider if you don’t already have one.
Other advantages include:
Troubleshooting which requires verbose logging and/or frequent restarts does not disrupt the operation of the production server
Reconfiguration for data capture does not disrupt production system. For example, profiling with the Windchill Profiler is greatly simplified with a single Method Server, which can be easily configured on a test server.
Testing of potential fixes can be done without interfering with the production server.
This was a brief overview of common measures that can be taken to avoid some EDOWNs. Some of this may seem basic and plain common sense to you; if so, excellent, hold on to that mindset. Nevertheless, we see a significant portion of EDOWN cases that may have been prevented with these measures, which is why they were covered here.
On a final note, there is a new set of articles that outline the most common technical areas where EDOWNs occur and contain information including:
The main article is CS202168- How to avoid common Enterprise Down issues in Windchill, other related articles are linked from that one. These will be reviewed on a quarterly basis to ensure that they reflect the most recent EDOWN analysis results.
Thank you for your time and as always, comments and feedback are greatly appreciated.
