Resource for reporting
Re: Resource for reporting
Added link in the TIPS and TRICKS section:
How to create a query builder report that accepts multiple inputs (PTC TS)
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS190138
How to hide the "Saved Reports" for particular user (PTC TS)
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS190136
Query Builder Report displays duplicate entries (PTC TS)
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS146646
Query builder report to fetch all the values of the multivalued attribute in single row (PTC TS)
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS210938
Marco
Added link as shown below.
TIPS and TRICKS
Multi-valued attributes display multiple times within a Query Builder report
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS53268
Possibility to make reports in the query builder default to search in the current container
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS96881
Search on Windchill Report Builder are case sensitive though the Select criteria is "like"
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS168769
Where is the documentation for how to add Business Reporting to an existing Windchill installation?
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS115821
ADMINISTRATIVE REPORT (User/Roles/Group/ACL's)
Global Attribute Enumeration
https://www.ptcusercommunity.com/thread/119387?sr=stream&ru=281467
How to export all ACL's related to a specific user
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS123564
Query builder report to fetch product, role and user from role
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS189509
Query builder report to fetch "last logged in" of users
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS220318
Query Builder Report to list all objects shared between projects
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS209852
Query Builder report to show folders with associated domains
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS44018
CHANGE MANAGEMENT
How to get "Promoted on" attribute into a Change Notice report
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS115668
Query Builder report for counting the Affected Objects in a Problem Report
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS213950
EPMDoc REPORT
Query Builder report to fetch checked out objects in user's workspace
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS134496
Query builder report to fetch the EPMDocuments having annotation
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS210700
PROMOTION and WORKFLOW
In which database tables are stored the workflow execution objects?
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS214035
QML report returning runtime routing list for Setup Participants from a workflow
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS210243
Report to find out values of Promotion Preferences
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS215586
WTDOCUMENTS
Query builder report to list Documents from folder
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS208539
Report to find WTDocuments went for Approval Routing in Windchill ProjectLink
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS207521
Report to search for Documents by Effectivity
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS209206
What are the tables and joins required for generating a query builder report for Documents without any Primary Content and Attachments
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS209629
WTPARTS
How to create a Where Used report for WTParts
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS210416
QML Report to to show association between Deviation and it's associated WTPart
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS205475
Query builder report to list WTParts from folder
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS208537
Query Builder Report to list all the OEM part which do not have AML\AVL Part associated
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS210102
Query builder report to fetch parts at level 0 in structure tab
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS215346
Which Database tables store classification attributes in Windchill PartsLink
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS172788
TROUBLESHOOTING
Change Requests not automatically associated with corresponding Problem Report
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS211530
Failed to delete some report templates from Site>Utilities>Report Management
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS185149
Generating a report from Context > Reports > Change Request Logs caused MethodServer to crash with OutOfMemoryError
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS203309
Reports imported or created at Organization level are not available for non-admin users on Homepage
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS52000
Report Builder is inadvertently removing a condition from the subquery while attempting to modify the qml with user entered data
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS186246
Using Date Picker in a OOTB Report in a browser that is not in English results a "Timestamp format" Error
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS215342
Marco
TIPS and TRICKS
How to create bar chart report with number of records created in each month
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS223720
Use of Options in the Select Tab of Report Manager
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS35281
Information regarding how to use the Query Builder functions
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS83196
How can a report be run on a schedule and emailed to a user in Windchill PDMLink?
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS140996
Query builder report to display "Comments" column of Object
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS157262
How to allow users to see all part numbers even though they do not have access to all parts?
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS223072
How to add Info (Details Page) button and email links in query builder reports
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS227239
Query Builder Criteria Logic for getting last month
https://www.ptcusercommunity.com/thread/130187?sr=stream&ru=357802
ADMINISTRATIVE REPORT (User/Roles/Group/ACL's/Generic Report for different object)
How to generate a Query builder report to display Maturity History of the object
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS28221
How to get "Download" event information in Security Audit Reporting
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS135740
Query Builder report to fetch latest version of WTDocument,EPMDocument and WTPart in Library Context for particular state
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS142076
QML Report to list all the Users in Organization
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS198022
How to list Classification Nodes and their related attributes
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS220979
QML report to retrieve the Distinguished Name of all Users
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS221494
Query builder report for listing prohibit publishing objects
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS226376
Is there a way to Search Check in comments for CAD or Documents
https://www.ptcusercommunity.com/thread/130236?sr=stream&ru=364762
CHANGE MANAGEMENT
How to create a visual monitor report that shows open, in progress and complete Change Requests
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS224065
Query builder report to fetch problem report with associated part
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS226330
Change object Date Completed
https://www.ptcusercommunity.com/thread/129761?sr=stream&ru=5134
EPMDoc REPORT
How to get a list of all family table instances with a status of "Unverified" or "Unknown"
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS40247
Query Builder Report to fetch the universally uploaded object
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS227691
How to build a report for latest version of EPMDocuments
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS33305
WTDOCUMENTS
QML report to count the number of documents by different document types
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS216381
WTPARTS
QML report to query latest version of all WTParts
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS138336
How to get a query builder report for Classification details for Parts and/or Part Structure
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS145972
Query builder report to list WTParts of particular view
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS208737
https://www.ptcusercommunity.com/message/425216#425216
How to create a Query Builder report to list all Parts that do not have Parent Part
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS223922
TROUBLESHOOTING
When a variable is used in Select and Criteria section of Query Builder with Input Parameter, report page generated doesn't display alias name of variable in Input Parameters section
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS133386
Not able to Save reports having Chart using Organization Admin user giving secured action error
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS179575
Failed to export the results generated for Reports using Report Manager
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS204259
Information or Details page for Report Templates shows Creator attribute value as ???createdby??? where creator is not available
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS221397
Data monitor criteria filter for created on time of "Yesterday" not covering entire day
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS226634
In Report Builder, like operator does not returns exact searched string
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS224643
Report result will not be merged even select the "HTML (with merging)" in "Generate Legacy Mode Output"
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS222197
Soft types created at the organization level not available in Query Builder launched from "Site" > "Utilities"
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS227163
Marco
I'm looking to build a report that gives me the number of days spent at each state for each Change Notice. Can anyone recommend how to do this using functions within the Query Builder?
Conor
Conor,
I suggest you a couple of things.
First: you should create a dedicated discussion with your request, because you made it in an article.
Second: if you can't get an answer in few days, and have an active maintenance, you should also submit your request to PTC support.
Many of the reports linked in my document are taken from article written by TS.
Marco
Thanks Marco, will do that now
Hi ,
  I just posted a large amount of reports to the group. I do believe there are a few in regards to process and activity completion time. Please take a look at these reports and see if one can be modified to meet your need.
‌, Please feel free to add these to the document as needed.
Best Regards,
Dax
Hi Dax,
thanks for sharing your reports.
I'll take a look into them and then I'll link your reports in my document.
Marco
Hi Dax, thanks for these. These will come in useful!
Added link to reports taken from Dax Williams documents.
Action Item with Workflow Process
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111660/ACTION%20ITEM_Action%20I...
Attribute Ids by Name
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111682/ADMINISTRATIVE_Attribute...
Attribute Info
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111683/ADMINISTRATIVE_Attribute...
Document Template Info
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111686/ADMINISTRATIVE_Document%...
User Login Audit
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8686-1-111789/ADMINISTRATIVE_User%20Lo...
User Login Totals
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8686-1-111788/ADMINISTRATIVE_User%20Lo...
User Specified Preferences
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111696/ADMINISTRATIVE_User%20Sp...
Preferences
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111680/ADMINISTRATIVE_9.1%20Pre...
Quantity of Measure
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111692/ADMINISTRATIVE_Quantity%...
Report Manager Report List
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111693/ADMINISTRATIVE_Report%20...
Team Template Info
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111694/ADMINISTRATIVE_Team%20Te...
Part Version Scheme
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8682-1-111704/AUDIT_Part%20Version%20S...
Lifecycle Template Info
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111688/ADMINISTRATIVE_Lifecycle...
Library_Product_Project Templates
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8681-1-111687/ADMINISTRATIVE_Library_P...
Total EPMDocuments and File Size by Context
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8686-1-111791/ADMINISTRATIVE_Total%20E...
WTDocuments with File Size
https://www.ptcusercommunity.com/servlet/JiveServlet/download/8686-1-111787/ADMINISTRATIVE_WTDocumen...
Marco
