Check out this video on Using Windchill "Data Collaboration - ProjectLink" in from PTC Application Engineers
Presenters: Jason Petersen (Solution Consutlting, Principal) and Ryan Butcher (Solution Consulting, Fellow).
Original Date Presented: June 15, 2022
To dive deeper into the subject, check out PLM Collaboration
Webcast Q&A
Question from Eric: Can users customize/create templates?
Answer: Template creation and editing can be granted to users as needed. Typically, this is done by an admin.
Question from Eric: Can I invite a participant to view an assembly in a project who does not have access to the associated product?
Answer: Yes
Webcast Q&A
Question from JP: Is the object that Dave has checked out in ProjectLink locked for PDMLink users?
Answer: Yes, when PDM check out is used when adding to a project, it is locked in PDMLink.
Question from JP: Does a user get an email when a comment is added to a discussion?
Answer: Yes, if the user subscribes to a discussion topic.
Webcast Q&A
Question from Michael: When an item is converted to "PDM check-out", does it force a PDM check-out in the common space?
Answer: Yes. Whether you initially use "PDM check-out" or convert a "Share" to "PDM check-out", it does a check-out on the PDMLink side.
Webcast Q&A
Question from Stuart: Is there a way to know there is something new in Dicussions without opening it?
Answer: Add the discussion table to your home page and track new comments there in the status column of the table.
