Check out this video on MFG Process Management in Windchill from PTC Application Engineers
Presenters: Steve Ingham (Technical Specialist, Principal) and Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: October 19, 2021
To dive deeper into the subject, check out Windchill MFG Process Management - PTC University.
Webcast Q&A
Question from Mark: We store all our ERP/PLM documents in PDF as "static" records. Can Windchill publish these documents (BOMs and reports) as PDF?
Answer: You can use Windchill reporting or PDF reports of the BOMs can be created as exported on the fly using the BOM report or Export tools from the structure view.
Webcast Q&A
Question from Patrick: Is there any way to have this functionality talk to a .drw? (Creo) We really only control our BOMs in the drawing itself, or is this functionality only available in Windchill?
Answer: This functionality is only available in Windchill. There is not a way to push this back to a drawing.
