Check out this video on Using Type and Attribute Manager in Windchill from PTC Application Engineers
Presenters: Ryan Butcher (Technical Specialist, Fellow) and Donna Fedeli (Technical Specialist, Principal)
Original Date Presented: November 2, 2021
To dive deeper into the subject, check out Windchill Type and Attribute Management - PTC University.
Webcast Q&A
Question from Kevin: Can you move the folders around after creation?
Answer: They are ordered alphabetically. Edit their name to move them in the structure.
Question from Kevin: Can you move them in the structure? Move a sub-folder to another folder?
Answer: You can move them in the structure through cut and paste.
Webcast Q&A
Question from Anonymous: I joined a few minutes late. Is today's webcast more beneficial to Windchill Admins than to end users?
Answer: Yes, however good for users to understand what is possible.
Webcast Q&A
Question from Randeep: Why was the internal name required again for using a reusable attribute that was already created?
Answer: As a reusable attribute, when it is reused under a specific type, it is assigned an internal name for that type.
Webcast Q&A
Question from Mark: Can Windchill be ran in Linux/Firefox?
Answer: Yes
